AWR mounts...YOUR PERSONAL PREFERENCE!!!
Gods Father
Post by Gods Father »
i already posted a topic about this bt it got turned into an FAQ before more people got to respond...i just wanted to know what everyone else has done for their stiffness in engine mounts...i know for the durometer theres like 70 88 or 95 just wondering what you all thought...seems to me 95 is a little overkill...i know people with stiffer mounts and it makes there car seem to rattle at idle and stuff...just let me know what you think...thanks
1993 MX-3 w/ straight neck KLZE swap...Probe GT 2.5in headers, Custom exhaust w/ test pipe and OBX Twin Loop Tip, Bully Stage 3 Clutch, Fidanza Flywheel, Pheno Spacers, HEI mod, Blaster SS coil, Probinator chip, TWM short shifter, AWR front and rear mounts (88 Durometer), and Corksport braided clutch line...so far
Ever see the lone rider of the night? Well he'll find you and then you'll never him again...
RX8SE3P
Re: AWR mounts...YOUR PERSONAL PREFERENCE!!!
Post by RX8SE3P »
I'm bumping this because I don't want to make a thread.
I was going to get some AWR mounts for my next ZE, stock mounts sucked. Should I go with 70 or 88. I don't rape the engine or gearbox, I want good shifts and driving comfort.
Can anyone shed light on the differences and which is best for good shifts and won't break engines etc?
1995 Eunos 30x KLZE
96mx-3
Post by 96mx-3 »
i have only tryed 88....and there brand new... but they dont shake my dash too much ... and no other rattles..but the engine doesnt move at all... which i guess is the point... would be nice to try the 95
marcdh
Post by marcdh »
Very pleased with 88s, created one rattle on my dash that I expect I can silence.
View Worklog
I have 88's in both of my cars... not sure what 70 or 95 feel like but I know the 88's are solid! went to the dyno and the engine didn't move at all :D but I don't think they have too much vibration inside the car (each person has his own preferences of course)... makes the whole shifting driving thing seem more olid :shrug:
Post by wytbishop »
I installed all 4 MSP mounts when I did my ZE install and I notice the difference. They are advertized as 30% stiffer than stock, which would make them about 70A. I find that the shifting felt tighter and a little less torque steer. I think 88 would be good if it didn't shake the car too much.
wytbishop wrote:I installed all 4 MSP mounts when I did my ZE install and I notice the difference. They are advertized as 30% stiffer than stock, which would make them about 70A. I find that the shifting felt tighter and a little less torque steer. I think 88 would be good if it didn't shake the car too much.
for the record I too used 4 brand new mazdaspeed motor mounts when I first did my ZE... and those wore out too quickly IMO but I have a feeling these AWR are going to hold up much better over time just because of how they are designed.
Post by wytbishop »
I wouldn't suggest getting MSP mounts. I got them because I have a fetish for OEM parts. I was merely trying to offer perspective on a softer engine mount.
fowljesse
Post by fowljesse »
Sort of on topic..
Which hardness is red? I got the rear mount, and it's red. It also came with the bushings for the transverse member (bonus!). They are blue. Do you know which hardness blue is?
Thanks, and sorry for the partial Jack :)
fowljesse wrote:Sort of on topic..
The transverse member mounts or "engine member mounts" are SRD... not sure what the durometer of the SRD products are... they are VERY hard though...
solo_ryder
Post by solo_ryder »
I have 88a mounts and love em
My old black car has 95a mounts in em that the new owner put in.
HOLY MAN does it vibrate. I do NOT recommend it for a DD car whatsoever, gnarly shifting and exhaust sound though, but very rough
Ryan
Post by Ryan »
Why don't you just make the mount into a solid weld, so your engine is effectively welded to the body?
fowljesse
Post by fowljesse »
Some all-out dragsters do. That amount of vibration can be tolerated for a few seconds at a time :|
Mooneggs wrote:for the record I too used 4 brand new mazdaspeed motor mounts when I first did my ZE... and those wore out too quickly IMO
What do you mean worn out?
I guess what I mean is that they broke and had too much movement after too short a period of time... I guess only time will tell if the AWR hold up...
