KLZE power steering pump compatible?
nightfire
Post by nightfire »
Hey guys. I searched but it's a pretty generic term and showed up in hundreds of threads. Couldn't find the answer though. :)
Is the P/S pump that comes on some KLZE engines (presumably out of a japanese MX6) compatible with our cars? Same connectors? What about the A/C compressor? Alternator?
Thanks!
- Gord
1996 MX-3 GS-ZE 2.5L 5spd
KLZE+LSD / Headers / KL02 VAF / Clutchmasters stage-I / Fidanza 9lb flywheel / Eibach Pro Kit / Tokico HPs / Urethane bushings & mounts / SSR Comp-C 16x7 / General Exclaim UHP 205/45R16 / Wilwood 13" brakes / Whiteline rear swaybar / Carputer / Software Crossover / Infinity components+subs / 41hz Tripath Amp9 / Trunk SLA batt / Keyless entry
JoshVK
Re: KLZE power steering pump compatible?
Post by JoshVK »
power steering pump. - Yes
Alternator - Yes
AC? i cut it out so?...
1996 MX-3 GS - rollin' on Rota Slipstreams, (Red, Deep Tint, Black Lip)
True Straight Neck KLZE with TB relocate. Custom Cold air Intake. 2.25 Exhaust to Bosal muffler.
ACT Stage 2, Fidanza Lightweight Flywheel, Short Shifter with CorkSport Bushings and SS Clutch Line.
Suspension Techniques Springs On Zx2 Struts. SRD Control arm Bushings, Custom Sway Bar Links
nightfire
Post by nightfire »
JoshVK wrote:power steering pump. - Yes
Alternator - Yes
Excellent. Thanks. :)
- Gord
hgallegos915
Post by hgallegos915 »
remember the alternator mod for it to fit in case u use the alternator :)
-hec
