I have a problem with my KL-ZE.. It has recently developed quite a bad missfire from a cold start, once the engine gets up to temperature the missfire seems to go away!
The car also trys to stall when I stop, the revs drop and will either go back to normal or will actually stall.
I have changed both O2 sensors, fitted new spark plugs, new HT Leads, replaced the disty cap and even replaced the IM gaskets... however none of this seems to have made a difference
This morning I cleared the ECU codes, run the car and got new codes - 17 and 23
Does anyone have any idea what might be causing all this?
Im running out of ideas now
Thanks
Jono
1994 (UK MX-3) KLZE (Jspec)
