I NEED your help locating a part, 1994 V6 Mx3 PICS ADDED
cgreen84
Post by cgreen84 »
I am looking for the belt adjuster, from the water pump to the power stering pump, its white metal and has a peice of threaded stock which provide tension to drive the pumps. any help would be great, just PM me, I will post a pic later. I also need the signal light swich, when i turn on the lights she will blow the fuse and the left signals are lit all the time, anyone else have this problem? can't wait to get her running again
cgreen84
Re: I NEED your help locating a part, 1994 V6 Mx3
Post by cgreen84 »
A common mistake people make is to ground the deck using the car's parklight or dimmer wire. This wire shows ground normally, but 12 volts when the lights are on. This is what blows the fuse.
could this be the problem witht he park lampos i wonder and the signals? or dop u guys think it is in the switch?
umcamara
Post by umcamara »
cgreen84 wrote:A common mistake people make is to ground the deck using the car's parklight or dimmer wire. This wire shows ground normally, but 12 volts when the lights are on. This is what blows the fuse.
That's my quote, I specifically remember typing that. Anyways...have you installed an aftermarket deck recently, or around the time this started happening??
'98 BMW 328is M-Tech
Feedback Thread
hgallegos915
Post by hgallegos915 »
you can get that adjuster iff any probe gt, mx6 or v6 mx3 at the yard. ive replaced mine once lol
-hec
Smith18
Post by Smith18 »
Any reason why your replacing that pulley tensioner? if you snapped the bold, you can still turn it till it tensions the belt... its really doesn't matter.
But yeah and KL engine from any of these cars are the same.
1993 Mazda MX-3 GS, V6 KLZE 2.5L, CenterForce Duel Friction Clutch, Nylon Shifter Bushings (from Imazda.com), Integra Cold Air Intake, Millenia Intake Manifold, Indigo Gauges, Pacesetter Header->Resonator->2.5" piping->Dynomax Muffler, VSX Front and back bumpers from FX Designs, AWR Front and back Motor Mounts.
cgreen84
Post by cgreen84 »
the white metal bracket broke and yes i did change my deck
cgreen84
Post by cgreen84 »
call all yards here in newfoundland today, no dice damnit! back to the hyundi boooooo
Jepha
Post by Jepha »
Nice to know I'm not the only mx3'er in Newfoundland :D
Sorry i can't help though.
cgreen84
Post by cgreen84 »
anyone know where i can order one on the net???
cgreen84
Post by cgreen84 »
umcamara
Post by umcamara »
cgreen84 wrote:the white metal bracket broke and yes i did change my deck
Rewire your deck's groundwire to a proper ground, that should solve your lighting issue.
Feedback Thread
cgreen84
Re: I NEED your help locating a part, 1994 V6 Mx3 PICS ADDED
Post by cgreen84 »
thanks, any word on the name of the part i need? Anyne have the part #?
cgreen84
Post by cgreen84 »
1994 Mazda Mx-3 ... need water pump belt tension assembly ( brace , pulley , and manual adjuster)
Slammed6
Post by Slammed6 »
I got one for sale...but shipping to you might be expensive.
PM me your address and i can check it out.
-Devin
cgreen84
Post by cgreen84 »
its actually the one circled in yellow Image
I am located in St. John's NL, postal code A1A 5H2, whats the cost, I'll buy the two of them if u have both. Also I need a signal light switch
Locked
