96 ECU differences
96 ECU differences
I have a 96 GS that I want to ZE. Problem is the ECU pins are different. Can anyone point me in the right direction to either get my ECU chipped or if a Jspec ECU for a 96 exists. Thanks
RS_OBD'oh_2
Re: 96 ECU differences
Post by RS_OBD'oh_2 »
I had the same issue with the 96 RS. There are too many different pins. Save yourself the trouble and swap the harness and ecu.
I was told swapping the harnesses is a biotch of a job. I've messaged "The Probinator" to see if he has a modded chip for the 96 obd2 harnessed engine. (KLZE) I await his response.
JoshVK
Post by JoshVK »
Daninski wrote:I was told swapping the harnesses is a biotch of a job. I've messaged "The Probinator" to see if he has a modded chip for the 96 obd2 harnessed engine. (KLZE) I await his response.
he told me he cant...
Just out of curiousity where did you get you KLZE?
1996 MX-3 GS - rollin' on Rota Slipstreams, (Red, Deep Tint, Black Lip)
True Straight Neck KLZE with TB relocate. Custom Cold air Intake. 2.25 Exhaust to Bosal muffler.
ACT Stage 2, Fidanza Lightweight Flywheel, Short Shifter with CorkSport Bushings and SS Clutch Line.
Suspension Techniques Springs On Zx2 Struts. SRD Control arm Bushings, Custom Sway Bar Links
zzzoomx3
Post by zzzoomx3 »
hereis a list of places to get a KLZE. from what i understand - and i could be wrong - you should be able to use your ECU with the ZE. in my 93 MX3 1.8 - i installed a 96+ ZE and was able to use my original ECU, but i did have to change out the disti - due to the firing order on the ZE being different. while i was at it - i swapped out the coolant inlet (with the secondary coolant sensor) and redid my timing belt. now my car is one fast a-- beast - literally. i am beating just about anything that comes my way - including an IS300 and an F2T my buddy has in his 626 and i havent even rechipped my ecu yet. cant imagine what a beast it will be then. i know that you cannot use a 626 or MX6 ecu that came out of a car that did not have the secondary sensor on the coolant inlet. it will not turn your fans on - that was my experience when i tried this.
why do you want to switch ECUs anyway and not just use the K8 ECU? or am i missing something?
Ya your 93 MX3 is OBD1 (EEC4) but my 96 MX3 is OBD2 and thats a different ECU. I don't believe the year of the ZE matters it's the fact that the newer ECU's can't be chipped so my VRIS and fuel management will be wrong.
Anyone know if there's a Mazda OBD2 to OBD1 conversion harness out there or if it can even be done that way if I build one myself?
zzzoomx3
Post by zzzoomx3 »
then just get a ZE ECU then - right?
Just to close this post. There are no ZE OBD2 ECU's. No chips, no nothing. Install the ZE ensure it's configuered like your 96-97. Once installed use a KL02 VAF, set your TPS, idle and then buy those MDS window switches for the VRIS. Thats it.
