Page 1 of 2
ZX2 SR struts and .... - Questions
Posted: April 1st, 2008, 10:34 pm
by JoshVK
Ok So i think i want to go with the ZX2 struts,,
I have 15inch wheels and currently save 50 profile tires. but i think i might go back to the stock 55 size
anyways id like something fairly tight and i want to go lower, not too low, but low enough to make 15s with 50 or 55s look right and nice on my car...
and still keep things reasonably priced. like the 230 on struts, 50-200 total on spring, spring/sleeve setup
anyways since im unsure, i think a coilover set up would be awesome.... eg. the Dropzone Coilovers.
This link would have helped alot but the link in first post dont work anymore.
http://www.mx-3.com/phpBB3/viewtopic.php?f=36&t=42037" onclick="window.open(this.href);return false;
Re: ZX2 SR struts and .... - Questions
Posted: April 1st, 2008, 10:38 pm
by umcamara
Beware of the name DropZone...
Posted: April 1st, 2008, 11:42 pm
by wytbishop
DropZone is code for junk. In the end, there's no way to do your suspension well for less than about $700.
$200 - 250 for struts
$200 - 300 for springs
$50 for alignment
Plus the little things like bumpstops which are usually toast and strut bearings which are often broken. Add shipping if you have to order struts and springs online...which you likely will. If you try to cheap out, you'll wind up with a bad handling car.
Posted: April 1st, 2008, 11:48 pm
by umcamara
I have to recommend
http://www.oemfordparts.com for the ZX-2 Tokico struts, as well as two metal thrust bearings. They were the cheapest I could find anywhere, about $240 shipped to Canada. As well, their service was excellent.
Posted: April 1st, 2008, 11:55 pm
by solo_ryder
Here is a pic of my old mx with tokico HP and suspension technique springs on stock tires:
I liked those springs, they advertised a 1.3" drop, it settled at like 1.8"
H&R is a nice stiff spring
Intrax is a nice progressive spring
There are lots, they will all yeild a 1.3-1.8" drop.
With my current car I am running zx2's with a ground control coilover sleeve setup.. VERY much better for handling etc. Abit bumpy though
Looking at that old pic kinda makes me miss the look of that old car...
Posted: April 1st, 2008, 11:56 pm
by hgallegos915
man that looks BAD a--!
Posted: April 2nd, 2008, 2:34 pm
by wytbishop
umcamara wrote:I have to recommend
^^^I totally agree.
Posted: April 2nd, 2008, 3:06 pm
by JoshVK
hmm.. How much was duty on those? (struts)
How low do the H&R springs drop?
and The Eibach?
Posted: April 2nd, 2008, 3:30 pm
by solo_ryder
You can get the shocks from any large ford dealer. I got mine from Brown Bros. Ford in Vancouver for 240bones taxes in. Check a local ford dealer.
H&R should yeild a 1.5" drop
Posted: April 2nd, 2008, 3:41 pm
by JoshVK
I live near the border Windsor/Detroit, think i just drive over one day and get em, along with the thrust bearings.
Still yet to make up my mind on the damn springs.. lol
Problem is planning to do to much at once.. lol Im Currently finishing school 4 hours from car and trying to find all parts so i can do Engine swap, Suspension and some body maintenance in about weeks time when i get back.. haha
Posted: April 2nd, 2008, 5:07 pm
by wytbishop
My local Ford dealer had em' but at about $75 more than oemfordparts.com so it was still cheaper to get them from texas. With the Eibach Pro Kit lowering springs the drop is perfect for my taste. Just centers the wheel in the well perfectly.
Posted: July 20th, 2009, 3:47 pm
by Daninski
I know this is an older post but I'd like advise here. My car runs like a tank, very stiff. I have 17's on the car and I don't really want to drop the car at all as the streets here have real bad curbs. What springs should I use with the zx-2 struts to achieve a little less of a hard ride. My springs are stiffer then stock but I do still have lots of stock springs around I could use if that would work. Advise anyone. Thanks
Posted: July 20th, 2009, 4:03 pm
by umcamara
I would use the stock springs, they should ride nicer.
A lot of people on here have the misconception that the ZX-2 Tokico struts automatically lower your car half an inch. This is untrue, it's just that the stroke that the shaft undergoes is half an inch shorter.
Makes no difference to the ride height of the car.
I'd love to put stock springs back on for the ride comfort, but the wheel wells look like crap like that.
Posted: July 20th, 2009, 4:38 pm
by wytbishop
The stock springs will be the most comfortable. The Escort ZX2 springs are a little harsher than the stock ones.
Posted: July 20th, 2009, 8:15 pm
by Daninski
With my mounts filled and the stiffer springs and shocks I've lost two fillings already.
So now to find a reasonable place to buy the struts. Thanks
