Clutch grinding noise in neutral
Posted: March 6th, 2008, 3:06 am
by AlexMX3
Now my clutch seems to be working just fine. It still pulls strong. While in neutral
for some reason it makes a grinding noise and when i slightly step on the clutch it goes away ( like 1/4 of the way down)
The grinding noise comes and goes.
Does anybody have any idea what this means?
btw it's a 1993 v6.
Re: Clutch grinding noise in neutral
Posted: March 6th, 2008, 3:40 am
by fowljesse
I had an RX7 that did that and it was the throwout bearing. I never did anything about it, and it never changed. I had the car for about 2 years. I would recommend changing it, though.
Posted: March 7th, 2008, 5:26 pm
by kab-rst
i had those problems,
i did like if it neer happeneds, the clutch was still pulling fine after all
one day the bearring broke off, cost me a 200$ tow, and i had to open up my transmition just for a 30$ bearring
turn out it happened to me again ,not to take any chance, i changed my clutch kit andreplaced everything by some new stuff
it allways broke when it'S not the time
first time it was years of wear
the second time it broke a pin on it
here what it looked like on the second time
![Image](http://i2.photobucket.com/albums/y47/kaboshe/rst/IMGP3760.jpg)
Posted: March 7th, 2008, 11:53 pm
by Raven95150
Definitely the throw out bearing. Chances are you can still drive it for a while but as the last post said, it could leave you stranded one day. Not to mention, it could cause damage to other parts when it goes. Since you have to take the tranny out, I would just get a whole new clutch kit and replace the whole works while you are in there.
