is it Possible V6 auto tranny ...
Can I some how swap my ATX axles in my GS for MTX axels, I have a flawless set of MTX V6 drive shaft and axels, and my ATX V6 ones are making a lot of noise! Is there a way to take tranny apart and swap the female spline inerds!! Or Hey any body want to swap set for set? Thanks Dan....
- se7en
Re: is it Possible V6 auto tranny ...
one side is the same. but I forget which
7
7
Raven95150
Passenger side is the same, drivers side is not.
You can't just swap parts out of an MTX into an ATX, they are completely different. Even if you could, thats a lot of work just to make a CV shaft fit. At that point, you would just be better off doing a MTX swap.
No more MX-3
2005 Hyundai Tiburon GT
95 F-150...6" lift, 35" tires
