okay, this is wierd.
i run perfect A/F ratios when I first start up the car and go boosting, but after about 35-40 seconds, it really runs lean under boost.
what the heck ?? i think the computer when it warms up, it thinks that it should run lean for some reason. I don't know why though... you would think the computer would run richer if there was any problems....
anyone have any ideas?
7
wierd new lean problem.... again :)
- se7en
- Flinch
Re: wierd new lean problem.... again :)
lol man when i can down there we whould have tried my extra K8 ecu. i though all cars ran richer when you first start them up cold untill they warm up totaly.
-KL31 stock internals with curved neck intake manifold and KL36 ecu
-Turbo running 7.5psi
-FMI 3"x12"x32" all alluminum and welded, have a 7.5 PSI spring she just creeps on cold nights
-ACT 6puck sprung/96 probe tranny
-Short shifter
-HEI and MSD 6al (makes a big difference when you spend the 65$ ont he right spark plugs)
-KYB GR-2 struts with H & R springs
-Megan racing seats
-Personal 280mm stearing wheel
-Familia rear strut tower bar
-Short shifter
-Megan racing seats
- tehbrookzorz
I think I'm gonna be bugging you guys for help when I get my KL installed. Know MSnS V3?
Cody
Are you boosting on the stock ECU???
OSKY
95 MX-3 GS ZE Turbo: MSnS-extra, AEM WB, Blitz boost controller, MSD 6A w/ Blaster2 Coil, ZE disty, Redtops @ 550, Walbro 255, Garrett T3/T04E 60 Trim w/ .63 A/R, 38mm Deltagate Mark II @4psi, FMIC, Apexi BOV, CM Dual friction, 4-6.25 Kickers, 2ch Alpine V12. That's Alll.
http://www.pakfeifertuning.com
- se7en
ya lol, I am getting a MSnS soon(week), but for now, I use an FMU(vortech), which some people seem to be having good luck with.
Thats why your leaning out. Your stock ECU has no idea your running boost. The FMU is not enough to add the required fuel for 7 psi; not even close. There are some calculations you could do to determine how much fuel you need. You'd probably find that its more than the injectors your running can physically handle.
Dont tell me your running stock fuel injctors as well???
Did you get a copy of Corky Bell book?
OSKY
- solo_ryder
He's running 220cc DE injectors on his K8 with a AFPR as well FYI
- se7en
some people here had plenty of success(andy,antwan, and others) with the fmu setup. and yes. I upgraded my injectors, and I have read corky bell's bookEZ_4_FUN wrote:Thats why your leaning out. Your stock ECU has no idea your running boost. The FMU is not enough to add the required fuel for 7 psi; not even close. There are some calculations you could do to determine how much fuel you need. You'd probably find that its more than the injectors your running can physically handle.
5 more days till I get my MSnS.
7
