another injector problem I think??
Posted: January 4th, 2008, 1:19 am
I was checking the ohms on my injectors, and now the car won't start.
did the ohm meter send voltage to the injectors and cause my car to flood maybe??
every connector and vacuum line is hooked up right to, so now what??
also, it seems like spark is intermittent. that could be because of the flooding from the ohm meter?
I already have the HEI mod, and it is grounded really well, and the back of the hei module is heat insulated right too. I also removed my disty cap, and checked the coil adapter thingy(tower of power) and the ohms there are good, and the cap is new.
it seemed that at first, only two cylenders weren't sparking, then after ohm testing the injectors, they all only fire intermittently. what the heck?
could my hei have crapped out maybe? how do I test it?
also, the coil seems to be okay still.
any ideas folks?
7
EDIT: this all started happening after I changed to the USED injectors.
which btw: the front three have 15 ohms resistance and the back three have 25 ohms resistance. could the fault be in the back three injectors? because they are out of range a little bit.
any ideas folks?
7
