koni struts prefered spring?
Posted: December 6th, 2007, 5:37 pm
by chertel
What kind of springs would be best with the koni front struts? I was thinking Eibach?
thank's
chris.
Posted: December 8th, 2007, 8:17 am
by mx3autozam
I think the best setup would be Ground Conrol coil overs whiuch ahve Eibach designed springs.
you do know that the koni's are a cartridge that you install into the stock strut, then you choose what spring you want. But ya Eiback would be pretty good choice. same with H&R.
Posted: December 9th, 2007, 5:59 pm
by chertel
Thank's I chose eibach first but they were out of stock so I went with my second choice being H&R because they were in stock and a little cheaper.
later
chris
Posted: December 10th, 2007, 5:01 pm
by nope-mx3
chertel wrote:Thank's I chose eibach first but they were out of stock so I went with my second choice being H&R because they were in stock and a little cheaper.
later
chris
In my opinion the H&R`s are a better choice, as they are a bit stiffer, and lowers a bit more than the eibach`s.
-n
Posted: December 10th, 2007, 8:39 pm
by Flyer
Speaking of Koni Inserts, anybody know the maximum spring rate these things can handle?
