mx6 rotors
kenken
mx6 rotors
Post by kenken »
does a 1992 626/mx6 rotor fit into a gs? thanks
solo_ryder
Post by solo_ryder »
no, they are a 5 bolt design, we are 4x100 bolt design
kenken
Post by kenken »
if i send to the shops and make it 4x100..does it fit nicely?
bdr2k5
Post by bdr2k5 »
kenken wrote:if i send to the shops and make it 4x100..does it fit nicely?
not need for that, get mx-3' rotors
93 mx-3 w/ Curved Neck klze
Custommx3
Site Administrator
Post by Custommx3 »
mx-3 rotors are ~$20...
mx3autozam
Post by mx3autozam »
I have a set of MX6 rotors here. At one point I was going to use them for a simple 5 lug conversion. I am still not sure if I am going to do it or not.
kenken
Re: mx6 rotors
Post by kenken »
are mx6 rotors any bigger than stock gs ones?
solo_ryder
Re: mx6 rotors
yes
Re: mx6 rotors
Could always go with Miata rotors, those you can get a bit larger I believe.
Any reason why you want to go with larger rotors? Larger rotors add adition rotation mass which would actually slow down your acceleration. All one needs really is a good set of pads and rotors.
