Besides 205/40/17, can a gs with stock struts fit thicker tires like 215/45/17 or 215/40/17?
thanks
17inch rubber size
- solo_ryder
Re: 17inch rubber size
204/40/17 = 23.45" wheel diameterkenken wrote:Besides 205/40/17, can a gs with stock struts fit thicker tires like 215/45/17 or 215/40/17?
thanks
215/45/17 = 24.61" wheel diameter
215/40/17 = 23.77" wheel diameter
In general, if you want to increase tire width, you must decrease profile ratio to maintain the same overall wheel diameter. The stock tire size for a K8 is 205/55/15 which makes for a stock wheel diameter of 23.88" and that is the size that your speedo is geared to. If you reduce the overall wheel diameter, each revolution of the differential will result in less distance traveled on the road and your speedo will read high.
If you want your speedo to be correct, go with 215/40/17. It will have an effect, but it will be small. Stock offset is 45mm...so watch your backspacing as well.
stock offset is ET45 on the GS 15 inch wheels, you should be fine with that offset.
