clutch pedal feel
- lowflyinmx3
clutch pedal feel
I bought a 94 gs about 2 weeks back with a bad rubber clutch line. I got the part in monday and got her up and running. The pedal feels much nicer now but it's still sloppier than my old rs. I bled the line by myself and I was wondering if I bled the line while someone is on the pedal would that help with the feel? Or is the stiffiness also affect by the pressure plate? Thanks
Mazda.... What happens in the parking lot, stays in the parking lot
I got a one man bleeder kit from the auto parts store that works well if you don't have a second person... you can also adjust the pedal by a nut to where it engages...
the feel will vary unless you have the exact same clutch and stuff...
![Image](http://i806.photobucket.com/albums/yy344/Mooneggz/laguna_seca_signature.jpg)
Re: clutch pedal feel
problably got stuck clutch, yeah the presure plate is really soft, i recommend a Centerforcelowflyinmx3 wrote:I bought a 94 gs about 2 weeks back with a bad rubber clutch line. I got the part in monday and got her up and running. The pedal feels much nicer now but it's still sloppier than my old rs. I bled the line by myself and I was wondering if I bled the line while someone is on the pedal would that help with the feel? Or is the stiffiness also affect by the pressure plate? Thanks
![Twisted Evil :twisted:](./images/smilies/icon_twisted.gif)
93 mx-3 w/ Curved Neck klze
- lowflyinmx3
ok thanks. I was just curious because I like a stiffer feel. It's got 225000 km's on the original clutch so when I replace it I hope I'll get a better feel. I know about adjusting my engaging point, I'm thinking about doing that as I occasionally hear the synchros grind on shift changes. Thanks mooneggs.
You know, I had my gear grinding for years, and though it was that common problem with our gearboxes, especially since it was 3rd gear so I start the custom one. Over the summer, my slave died, and they replaced it and my gears stopped grinding, too bad I panicked cause I was inthe middle lane in rush hour traffic and screw up 4th gear pretty good :S No matter, my new trans is hopefully just a few weeks away...just found out I need bearing races yesterday so I'm in the midst of ordering those now.
- lowflyinmx3
i was thinking it maybe a slave cylinder problem too, but i checked the work reciepts from the previous owner and they had it replaced not even a month before i bought it. and I've owned if for 3 weeks so I wouldn't think thats a problem. I just don't like the occasional empty THUNK sound I get when i shift gears sometimes.
