				[WTB]  AfterMarket Cams
				Posted: October 7th, 2007, 12:40 am
				by Stoney89
				I was wondering if there are any aftermarket cams that i could put in my 1.6L DOHC. Miata cams?
				Posted: October 7th, 2007, 12:48 am
				by Stoney89
				I found these OBX cams on ebay, 90-93 Mazda MX-5 Miata 1.6L B6ZE is what it says there for. Will they fit on the 95 1.6L DOHC MX-3?[/url]
				Posted: October 9th, 2007, 10:58 pm
				by Stoney89
				Does anyone know if these fit on the 1.6l DOHC
				Posted: October 10th, 2007, 7:49 pm
				by neutral
				They should fit just as well as if you installed a swap of 90-93 B6 stock Miata cams (which do fit the DOHC MX-3).  In other words, they'll fit but you'd have to do something like swap position of the Miata/MX-3 exhaust and intake camshafts in reverse position.  I can't remember the details, tried a search-of-all-terms for "miata cam swap" and apparently the UBB search function is still farked since a few days ago cuz I can't get a single hit on any search attempt, not even on the single keyword Miata.  I have a set of MX-3 stageII cam regrinds so didn't have to deal with the Miata swap Q.  Might want to try a UBB search later if you find the serach function has been fixed here...
				Posted: October 15th, 2007, 12:12 am
				by Stoney89
				so what type of cams should i buy to increase power?
