throtle body upgrade dohc
is there one availible? ive read the FAQ but as far as i understand they are only for the sohc. wil the TB from any other models fit??
1997 1.6 16v DOHC uk spec gs, 17" wolfrace triad, 2.0l probe s/s header magnaflow high flow cat, powerflow custom catback, CAI, zx2 struts w/ -40mm lesjofors springs
http://www.uk-mx3.com" onclick="window.open(this.href);return false;
Mnemonic
get it bored out at a machine shop
01 Lexus Is300 (LS2 Project)
93 Mx3 SE 2.5 KLZE (sold it)
- Limegreen mx-3
nope ur SOL so far..
thank god i never did like the 94+ mx-3..
i love my 92-93 mx-3's though
- TREVO123
If u were to do the 60mm, ud want to end up getting a Rx7 MAF/VAF and tunin it.
would the rx7 one not go on??
- Limegreen mx-3
hell no not the TB
Mnemonic
i mean you could get an adapter plate made and bolt a big mustange tb up but its not going to do much for you
- TREVO123
post a link!zCat wrote:Pretty sure Gude has a TB for the DOHC, as I am going to buy the kit and it includes cams, head, and TB.
Like 90% sure.
its a bored out tb......
zoom_zoom94mx3
http://www.gude.com/Head/hp.htm#mazda
that is all that they have on the web site, if you call them (they are in California) then they tell you everything....
94 mazda mx3 rs 1.6l DOHC... probe 4-2-1 header, 2" catback, a spec CAI, advanced ignition timing, NGK plugs/ wires, obx light wight crank pulley
http://www.cardomain.com/ride/2754605/1
found this in their products look at the bottom it explains the head kit...
http://www.gude.com/product_description.html
can it really give +55hp??
