ZE No Start
- Timmie_g
ZE No Start
I finished installing my KL ZE and now i cant get it to start.
Timing looks good
all sensors connected
it turns over and sometimes fires briefly but dies right away.
ive got spark fuel air.
My first thoughts are tb ecu combination. Currently on the car i have the curved neck manifold with a kl 68 throttle body and my K8 ECU because im waiting for my other ECU arrives. I am just trying to make sure the engine runs before i re install the axles and all the other stuff incase i have to remove the enigne again
If i put the K8 manifold and throttle body on do you guys think it will run
Timing looks good
- mx3autozam
- TREVO123
Make sure your plug wire order is correct.I made that mistake!
- mx3autozam
[quote="Timmie_g"]as long as the order is the same as it is on the cap then i shouldnt have an issue
im using the k8 disty[/quote]
double check them. they could be going to the wrong cylinders. Also check fuel lines. Did you swap the EGR from the k8 onto it with the manifold. You gotta make sure there is no vacumn leaks on that stuff.
- PATDIESEL
What did you do to correct the fuel issue. I think the K8 and DE use the same injectors so you could try using the ones from your K8 to make sure they are all giving a good spray. It is common that the injectors will gum up in an engine that sits for too long.
kfze klde klze all use same injectors, k8 use smaller ones, and kj uses the largest
01 Lexus Is300 (LS2 Project)
93 Mx3 SE 2.5 KLZE (sold it)
- PATDIESEL
oops, Brian is right, sorry for the misinfo. I was thinking the De and K8 were the same, but it is the ZE and DE that are the same. Meaning that you might not be getting enough gas with the K8 injectors.
- Timmie_g
its done
it runs decently despite having the wrong ECU installed.
but you know that feeling you have when you have a baby, i had it yesterday when i got it running
now i really need my ecu to come,
but heres another question if i have a probe gt ECU lying around can i use it if i dont have a probe VAF? will it run better?
