[FS] Megasquirt Group Buy @ ProbeTalk
I hope the mods don't mind if I post this
For those that don't visit or visit ProbeTalk often, there's a group buy for Megasquirt buids going on. I figured I'd spread the word since I've been waiting for one myself, but I stopped checking back after it was said that there more likely wasn't going to be another one and would of definitely missed it if it wasn't for n2ogsze.
As per their BB rules, it's only valid for 30 days, so I'll expire on July 29th.
Thread is here:
http://forums.probetalk.com/showthread.php?t=1701233196
If your interested in it, probably would be good to take advantage of it since it may be another year for the next one.
Thread is here:
				2RotorsNaDream
				hgallegos915
Order sent w00 Turbo the right way here we go..
I got the econ my pak. well its pending his reply.
I only need for the ecu NOT to auto adjust the timing.. it says we can manually set it using a timing light. That way I can retard it.
Im waiting on his reply. did anyone mail payment yet?
-hec
				2RotorsNaDream
- mx3autozam
				2RotorsNaDream
				hgallegos915
ordered the color coded harness too. Not to bad
							-hec
so if I ever decide to do nitrous or turbo on my klze this would be a good investment?  How much would these setups normally cost?
I'm leaning towards the econo setup just because I am not sure what options I would need...
				timpronk
A used one listed here:
https://marketplace.grassrootsmotorspor ... age838.htm
Not part of the group buy, but maybe somebody wants to spend less if they are close to it. Have no idea if its the same, but it says megasquirt.
92 MX-3 GS 2.5 KLZE
14.385 @ 98.21
						14.385 @ 98.21
- ScooterBovine
Please tell me what I need here.
I have a KLZE, no mods. Running the K8 ECU and VAF.
So all I need is the Economy MS system and the wiring harness, and the IAT sensor (intake air temp) to make this work?
And this will allow me to not have to buy the KLZE ECU and VAF?
Or am I way off in left field?
No more MX-3.
				hgallegos915
No need to buy klze ecu and vaf.
							-hec
- ScooterBovine
				hgallegos915
you guys better get in on this! this is the last BB hes doing.
							-hec
