tensioner part....
wvurubberducky
tensioner part....
Post by wvurubberducky »
Will the main tensioner by the oildipstick/etc that tightens up your alternator belt inter change with the 93 probe gt?? or does anyone have this part they would sel, i need the nut and inside the bearing piece, i still have the pulley just not the rest of it. thanks
PATDIESEL
Post by PATDIESEL »
Call Mazda and ask them to cross reference the part numbers from your pulley and the MX-3 or MX-6 V6. If they are the same part number then they are interchangable, otherwise no. I doubt they are the same though.
