mx6 engine
mx6 engine
Can you put the 2.5l mx6 engine in an mx3?
yes u can, bolts right in and to the mx3 tranny as well, watch urself ...asking questions like that will end up with about 15 people telling u to uswe the "search" functon. the probe 2.5 works as well...
Full fx designs body kit, Apex lowering springs tokico struts, walbro fuelpump, klze, 17" sachhi wheels, b'm short throw shifter, ractive frount and rear tower bars, kl36 ecu. all for sale....pending
- Tunes67
Ford Probe engines are the same and will be the cheapest considering that the Probe was produced in much higher numbers than any of the mazda cars that came with the engine.
Tunes67
Tunes67
"So long.. and thanks for all the fish!" "Momma says VW Bugs are the devil" "This one time at band camp.. I stuck a flute in my Throttle Body" ![Wink ;)](./images/smilies/icon_wink.gif)
You can get the 2.5L KLDE out of Probe's, Mx-6, 626 and Millenia's.
- mr1in6billion
I would say the gain is very significant. Besides, the reg KLDE is 164hp, and the Millenia is 170hpWhisper wrote:golhap27 wrote:Yeah, you're definitely going to gain performance. Nothing amazing, but still MX-6/Probe GT's 160 HP vs. MX-3's 130 HP.
And upgrade the clutch to handle the torque
And while oyur at it, wouldn't be a bad idea to do the belts, waterpump, etc.
you make a very good point!Nd4SpdSe wrote:And upgrade the clutch to handle the torque
While the motor is out its the best time to do:
Timing belt
tensioner
water pump
and other misc belts and seals.
2002 Mazda Protege5 (Turbo kit 75% complete)
1996 Mazda MX-3 Gs KL-ZE
1994 Mazda MX-3 Rs (BP-T?)
my uncle already replaced all of those a couple months ago. He owns a car shop, so when i bought my car he took it for a month and did a lot to it.ho bag wrote:you make a very good point!Nd4SpdSe wrote:And upgrade the clutch to handle the torque
Timing belt
tensioner
water pump
Although that is good, all the external accessories will fit, i'm not sure about the clutch, if that was touched at all. Although not usually necessary, if it hypothetically was, even if it's new, if it's an OEM replacement, it wont handle the power for long, you'll need to get one that will, even the opinions of the Probe/Mx-6 owners is that an OEM 2.5L clutch is questionable. A stage 1 from a reputable clutch manufacturer is usually more than sufficient, pending on how you drive it of course (and a proper break in is necessary)
Honestly tho, if it that was done a month ago, I'm surprised you didn't do the swap then, would of saved you most of the trouble
