Coilover's ... ?
Coilover's ... ?
Hello mx3 gang
Soon i had the chance to order something from a friend of mine.
He can get cheap aftermarket parts for many car's, and he said he could get the following:
Interior digital adjusted TEIN coilover set for my car.
They arrive monday, is he wrong about this ?
K8 :: 136.8 bhp---160 nm---108.0 whp---118lbs/torque
ET: 15.567 @ 136 kmh (84 mph)
"Racing a Honda is like being in the special Olympics, you may win, but in the end your still retarded."
- tehbrookzorz
Re: Coilover's ... ?
id BUYOutlaW wrote: Interior digital adjusted TEIN coilover set for my car.
- Josh
yah MX6 and mazda 3 fo sho. but not for the MX3, you might be able to mod some over. keep us informed
if they make them for the right year mx6 then you could make them work... hmmmmmmm
ProjectMx
My BP and AWD build thread
Cardomain
93 Escort GT daily driving
Cardomain
- Custom_V6_Limited_SE
I just got Intrax springs and Monroe MacPherson Sensa-Trac struts. 1.75" drop (according to Intrax). Will be installing soon. They should really firm up the suspension It felt like the nose was going to hit the ground with my new brakes and tires whenever I decided to test the brakes.
'93 MX-3 GS SE:My Mods
Red Rocket wrote:I actualy just saw a set on ebay for the eunos, espresso or whatever it is. lol
isn't the eunos a name for mazda?
i know that the mx-3 is called the az-3, presso, and 30X .. looked all those up on ebay and nothing... i did find a miata set of teins is that what you saw?
ProjectMx
Cardomain
Cardomain
coilovers from mx6/probe will fit the mx3
intrax springs will not firm up anything over stock setup.Custom_V6_Limited_SE wrote:I just got Intrax springs and Monroe MacPherson Sensa-Trac struts. 1.75" drop (according to Intrax). Will be installing soon. They should really firm up the suspension It felt like the nose was going to hit the ground with my new brakes and tires whenever I decided to test the brakes.
Hey, thanks Steeb.Steeb wrote:coilovers from mx6/probe will fit the mx3
I havent gone to put them , but when i do ill keep everyone posted
Eunos was a name for a marketing scheme for the "High End" of Mazda in the early to mid 90's.projectmx wrote: isn't the eunos a name for mazda?
Think Nissan is to Infiniti as Honda is to Acura
Same idea. Only it was only ever proposed on the other side of the ocean whereas Acura is only on this side of the ocean
Drew
'95 EGT 1.8 T
'93 ELX 1.9 SC
'91 ELX 1.9
'95 EGT 1.8 T
'93 ELX 1.9 SC
'91 ELX 1.9
