Viability of P205/55R16 with ZX-2 Struts/Eibach Springs.
tehbrookzorz
Post by tehbrookzorz »
I know it sounds odd guys, but I want to run P205/55R16 tires on a 40mm offset wheel in combination with the ZX-2 Tokicos and Eibach 1.5" drop springs.
I haven't lowered the car yet. I've got my struts, I'm waiting on the springs, and somebody gave me the tires. I just need rims.
I recognize that there is a loss in acceleration from running a taller tire/wheel combination, but am okay with that.
Has anybody run a similar combination to what I want? How did it work?
Cody
tehbrookzorz
I guess I'll just have to try it and hope :p
Cody
Steeb
Post by Steeb »
i think the rears should fit cuz there is more room between the tire and the lower spring seat but fronts might not clear the lower spring seat.
tehbrookzorz
Hmm, maybe what I should do is compare the size of the stock strut 'body' with the ZX-2 one since I know that tire size will fit on the stocker. Is the actual black part of the strut the same size or is it half an inch shorter? I know that the strut is shorter overall but where is the length shaved off?
Cody
