VAF Relocation(NOT ANY MORE) but idle issues
Red Rocket
Just thought I'd ask if anyone has maved theirs. I'm toying with the idea and was just wondering if anyone else has done this. It was suggested that the resistance may change with the extending of original wiring, I'm not sure about this cuz wires is what I do, literally. But I appreciate any comments or suggestions.
- Tunes67
If wires is what you do then you should know that as length increases so does the wires resistance value. It may not be much.. but.. if the ECU is calibrated to a wire with a certain value.. if you then change the value.. the data the ECU receives would then be flawed.
I dont know if these harnesses have sensors with resistance wires or not.. But I have seen such harnesses before and they are indeed a PITA if you have to work with them. Older single wire O2 sensors used resistance wire as an example. And I am relocating my MAF as well and have no issue keeping the stock wiring harness and using it without modification. Best of luck.
Tunes67
Tunes67
Red Rocket
ok well all went great for fitting the cai. Made my cuts, removed neccesary components from the engine bay, tightened everything up and bam i'm idling at 1500rpm. So I gave it a bit to settle down, nope, bottomed out the idle adjust screw on the throttle body and it brought me down to about 1000rpm, but thats still too high and doesnt seem right. Anyone else have these issues.
By the way it looks and sounds great.
[*url=http:cardomain.com/ride/2632839]My Cardomain Page[/url*]
Red Rocket
ever since my klze swap my idle has been around 1500... sometimes it will stay around 800-1000 but majority of the time 1500... I'm sure something needs to be adjusted... I've messed with everything...just can't get it to go down... I've learned to live with it...
hgallegos915
why dont you reset the tps? make sure the iac is connected. Adjust the idle screw. Make sure no leaks at all. If you feel comfortable, adjust the throttle bory screws on the fly itself. My kfze was idling at 1.5 forever until i decided to adjust those screws and closeds the tb plate a bit more and walla. Idle at arpound 700 rpm.
-hec
- ScooterBovine
I may be wrong, but I thought that adjusting the screw by itself wasn't the right way. I thought you had to put the ECU in diagnostic mode by jumping some stuff, THEN adjusting the screw a little lower than where you want (ex if you want 800 rpm, you set it at 700 rpm), then take the car out of diagnostic mode...
But I dunno.
But I dunno.
No more MX-3.
hgallegos915
well yeah thats ho0w i adjusted by ten and ground then adjust and then pull the pin once its adjusted.(while car runing)
-hec
Red Rocket
- ruthless_mx3
check the link and read about 5 posts down. Jschrauwen has an awsome explanation on how to both adjust the tps and check the iac
http://www.mx-3.com/phpbb2/viewtopic.php?t=47561
its in the v6 faq for future reference
93 MX3 GS SE KLZE -- RIP May 1, 2011
14.007 @ 98.46 1.991 60ft -- the only time she made it to the 1/4
92 MX3 GS aka Goldmember - I'm trying to keep the legend going and as always credit to Andy for starting the legend
sc61 currently @ 8 psi, wiseco 10:1 pistons, K1 rods, ported ze heads w/ kl31 cams
