Replacing passenger side window hard?
I need to replace my passenger side window and I have a spare door. Has anyone done this? How hard is it to do?
2008 Mazda 3
1993 MX3 GS
1993 MX3 GS
- mitmaks
pretty easy, took me about 1/2 hr 2 years ago when someone busted mine
Any advice on doing it because I dont want to pay some guy $80 to do it for me
What tools will I need? How do I do it?
btw, online manual dont show anything
2008 Mazda 3
1993 MX3 GS
1993 MX3 GS
window and tools...
for mine all i used was a phillips head screw driver ( the 4 sided one) and rolled the track down to where i could see the two screws holding the window on. Unsrew those and clean all the glass out, slide the window into the door-make sure it is one track- line the two screw slots on the window and tighten the bolts in and that should be all there is to it. Mine are power and thats how it ws done, very easy.
- solo_ryder
Ok you guys are right. I found out the hard way. On my old damaged door with the good window, I just started to cut the the thing that holds the door cover. I cut about half of it off until I realized what I had to do. Really easy, dont know why they would want to charge me $80 for that.... a--holes they wont get a cent from me
2008 Mazda 3
1993 MX3 GS
1993 MX3 GS
