2.3l Miller Supercharger on k8..
can the 2.3l supercharger fit nicely on the k8 engine?
Probably no.
Use the Search function. If it has not been done before, it is probably very difficult/ impossible to do. At least impossible if you don't have unlimited funds...
'92 GS
My worklog
My worklog
the answer is no. the engines are just to different to swap over, the angles of the heads varies greatly
01 Lexus Is300 (LS2 Project)
93 Mx3 SE 2.5 KLZE (sold it)
- atlantamx3
- ccreech
Perry Has diagramed nicely why it won't work here:
http://www.mx-3.com/phpbb2/viewtopic.ph ... 37&start=0
5th post down when I searched "2.3 Supercharger" and that included this post.
I will sumarize:
Won't fit between the heads...So won't fit under hood...even if it would it is not your typical supercharger and would take a lot of modification. Actually...It would take more modifying to make it work than just about any other supercharger that you could possibly think of. They all would take a good bit of engineering to run from a drive belt, but it can and has been done with other superchargers. I would suggest going a different route. A picture is worth a thousand words...Look at how big it is and try to find a spot for it under the Mx-3 hood with the pully facing the belts.
![Image](http://www.atlantamx3.com/moca/chris/kjmotor051806/images/PICT0424.jpg)
I will sumarize:
