Lets Make an official SAFC 2 Wiring Thread!
Posted: March 11th, 2007, 3:30 pm
Well considering this is the worst topic to search for because every thread is a dead end or confusing as hell, we should make an official SAFC 2 wiring thread. Lets cover everything, where the ecu is located the color of the wiring, the wires you dont use on the SAFC, DOHC, SOHC, V6 ect. But first I need help for my car! Its a 95 1.6 L. Where is the ecu located, what pinouts you use so on.
Thanks guys.
So far I have this
SAFC Side --------------- Ecu Side
_________________________________
Red Wire (power) -> 1B
Gray Wire (tps) -> 2M
Green Wire (RPM) -> 2E
Brown Wire (Ground 1) -> 2C closer to the ECU
Black Wire (Ground 2) ->2C further from the ECU
White Wire (Airflow) -> 2o Wire 2 MAF
Yellow Wire (Airflow) -> 2o Coming off ecu harness
Blue Wire -> o2 Sensor (2N)
Set on hotwire sensor 11
Now considering Wire color from the online shop manual
Blue = L
Black = B
Brown = BR
Dark Blue = DL
Dark Green = DG
Green = G
Gray = GY
Light Blue = LB
Light Green = LG
Natural = N
Orange = O
Pink = P
Red = R
Purple = PU
Sky Blue = SB
Tan = T
White = W
Yellow = Y
Violet = V
So now according to the wiring diagram i am assuming the schematics would follow something along these lines
Red Wire (power) -> 1B (White and Red)
Gray Wire (tps) -> 2M (Blue and Violet)
Green Wire (RPM) -> 2E (Green)
Brown Wire (Ground 1) -> 2C closer to the ECU (Blue and light green)
Black Wire (Ground 2) ->2C further from the ECU (Blue and light green)
White Wire (Airflow) -> 2o Wire 2 MAF (????)
Yellow Wire (Airflow) -> 2o Coming off ecu harness (????)
Blue Wire -> o2 Sensor (2N) (Red and Blue)
So is this even the proper wiring for the DOHC??
Thanks guys.
So far I have this
Blue = L
Black = B
Brown = BR
Dark Blue = DL
Dark Green = DG
Green = G
Gray = GY
Light Blue = LB
Light Green = LG
Natural = N
Orange = O
Pink = P
Red = R
Purple = PU
Sky Blue = SB
Tan = T
White = W
Yellow = Y
Violet = V
