Help with Pulling Codes!
uk_mx3_guy
Post by uk_mx3_guy »
Hi,
I am trying to pull codes (if I have any) from my UK 92 1.8 V6 MX-3,
I am putting a LED between GND & TEN, When i switch ignition to ON, The LED comes on and the VRIS valves click open and closed, so it looks like it is testing, however the LED just stays on!
Does this mean all is ok? or is there something I am missing?
Thanks
Jon
UK 94 2.5L KL-ZE V6 MX3, KL-68 TB, Chipped ECU, Green Air Kit, Exceedy Race Clutch, Hand made exhaust system, Goodridge Braided Brake Lines, Black Diamond Drilled & Grooved Disks with Black Diamond Predator Pads
ariesdude
Post by ariesdude »
The light has to go between FEN & B+ and TEN & GND has to be jumped.
94 Mx-3 Precidia
uk_mx3_guy
Yeah I tryed that too and the light stayed on!
I also did the remove Neg from batt, then press brake for 20 secs!
But only did the test I said above, I will try again tomorrow!
Thanks
Jon
Vanished
Post by Vanished »
k wait did you clear the codes, and then try to pull them? Did you try to pull whilst it was running or when it was off?
1992 Blaze MX-3 GS *R.I.P.*
1993 Blue 93 SE-ZE
http://www.cardomain.com/ride/2770987/2
uk_mx3_guy
I cleared the codes, went for a drive, then tryed the TEN - GND while the car was off!
Jon
Vanished
Post by Vanished »
must have no codes stored. does the CEL even come on?
1993 Blue 93 SE-ZE
uk_mx3_guy
K, I checked again yesterday,
Wired TEN - GND & LED on FEN - B+
The LED came on for a few seconds then went off and stayed off! I assume this means there are no codes?
Jon
