Page 1 of 2
hectors 3rd gear pulls on me
Posted: February 21st, 2007, 11:12 pm
by PWRD_BY_HKS
every time we race its ussually head to head the whole track... i have drag radials, CAI, OBX headers, kl-31 ecu and 2.25 exhaust.
he has obx exhaust Straight pipe 2.5 inch exhaust , front and rear strut bars, real cai RAM air, NGK Spark plugs, stage 3 clutch, fidanza flywheel, SS Clutch Line, deleted ac/ PROBINATOR CHIPPED DE ECU,JDM Millenia Atlernator, no Kat no resonator., headers, HEI MOD installed and working. RS , 17 inch, Nan kang 215 40 r17 Garmin car GPS
and we both have the millenia manifold....
what does he have that helps him catch me on third gear... i mean ... off the launch i get him because of radials.... and i take him untill late 3rd gear.... sometimes we just end together ... sometimes he takes me depending on how good my launch is....
so what is it... can it be that i have a header leak, can that make me loose HP at top end.
Posted: February 21st, 2007, 11:26 pm
by hgallegos915
I think it has a bit to do with the flywheel and maybe probinator chip.. not to sure on the chip. hmm what else can it be? other than that we are the same.
Posted: February 21st, 2007, 11:27 pm
by Slammed6
I would say u should be running 2.5" header-back piping. 2.25 is too small for a KLZE.
Also like i posted in Hector's thread, on my KL-36 ECU i was running really rich, so when dropping in the Probinator EPROM i gained ~9 WHP...so that will help on top end.
Also his engine just may be running stronger than urs...its def possible
Posted: February 21st, 2007, 11:29 pm
by hgallegos915
i got 2.5 piping, i think he does too.
Posted: February 21st, 2007, 11:31 pm
by Slammed6
hgallegos915 wrote:i got 2.5 piping, i think he does too.
he put 2.25... :D
I am gonns have to say ur engine is just running better..lol.
Posted: February 22nd, 2007, 8:05 am
by mx3autozam
Does anyone have any legit proff that 2.5" is better than 2.25 on a ze. have 2.25 and some have 2.5" I may switch next winter if its that much better!
Posted: February 22nd, 2007, 12:49 pm
by Slammed6
There is an article that came out in i belive "Sport Compact" a while back and they actually did a dyno comparison. The article was to kill this myth of displacement tells the piping size u need.
The tested a 1.6 DOHC Geo Storm Gsi with both 2.25 and 2.5 and it made more HP with 2.5 but i don't recall how much...its been soo long since i read it.
They also tested a 2.4 DOHC Cavalier Z24 with both 2.25 and 2.5 and it made even a better difference, just can't recall the exact numbers.
I had 2.25 on my MX-6 at the time, and went and swapped out for 2.5". So this time when doing my MX-3 ZE i went 2.5" from the beginning. There is a WHP difference, i just wish i had the article and u could see for yourself.
Posted: February 22nd, 2007, 2:57 pm
by PWRD_BY_HKS
yeah im running 2-1/4 i need to up graded.... but you honestly think that will help out that much
Posted: February 22nd, 2007, 3:10 pm
by Slammed6
PWRD_BY_HKS wrote:yeah im running 2-1/4 i need to up graded.... but you honestly think that will help out that much
Well i remember it being somewhere in the neigborhood of 3-5 WHP, and i recall in the article the larger displacement made a greater improvement than the 1.6 but eitherway even the 1.6 gained anice amount of power by upgrading.
PS: Isn't stock piping 2"??
Posted: February 22nd, 2007, 3:19 pm
by PWRD_BY_HKS
im not too sure what stock is at...but i dont know what the deal-e-o is .... maybe i should get some better cams.... that would help...
Posted: February 22nd, 2007, 4:02 pm
by Slammed6
Do you both have KL-31 Cammed KLZE's with curve neck manioflds...or KL-01 cammed KLZE's??
Posted: February 22nd, 2007, 6:08 pm
by PWRD_BY_HKS
no both are kl-01s with curv necks...
Posted: February 22nd, 2007, 8:07 pm
by tehbrookzorz
Hector's also running a more consistantly powerful ignition system. I haven't seen dynos done to compare between stock and HEI, but there has been much talk about it.
Posted: February 22nd, 2007, 9:38 pm
by jdMx-3KID
i was running full interior minus the tire and jack.... and i have a header leak... could the header leak be throwing me off... i mean it does back fire pretty hard at high rpms...
Posted: February 22nd, 2007, 9:54 pm
by XxantwawnxX
i alwasy thought stock piping for ze cars was 2.5 thats the only reason i got it. Im sure the flywheel is helping him too....
