Hello All,
Have been looking into getting a decat pipe as my Cat is nackared and makes rattling noises on excleration. I have looked on the net with no luck have seen some on ebay from the states but not from the UK. Any one know of a UK store where I could get one???
Decat pipe for UK
Decat pipe for UK
MX-3 V6 - K8 - Alpine Stereo, Amps, Speakers ICE. Power flow stainless custom exhaust system cat back and de-cat pipe. Induction kit next.
- neutral
Don't know about UK sources but since you mentioned a rattle on accel, have you looked for a loose heat shield around the cat or exhaust piping? They are known to get loose with age and can usually be repaired with a large hose clamp tightened over the loose area or just remove the shield. I usually can find the loose spot by tapping lightly on the exhaust system with knuckles or a small hammer when the engine is cold - you'll hear the rattle and be able to isolate the location.
-Jim- TheBlackMoth
They are available on UK ebay mate, check here:
http://cgi.ebay.co.uk/Mazda-MX3-MX-3-1- ... dZViewItem
Lookin Good
http://i36.photobucket.com/albums/e18/o ... 000493.jpg
1.8 V6, MODS: Richbrook Steering Wheel, Green Cotton Air Filter, 16" Wheels, Speakers, Sub+Amp
MODS Planned: White Dials
Found one from the US.
http://cgi.ebay.com/ebaymotors/ws/eBayI ... 0088124944
Only problem when I got it and went to put it on it didn't fix...... It was too long had to get it made to size. All on now and car runs a lot better. Thanks for the help.
