Couple of things you should know before replying to this: the car is a GS 92 with G5M-R and LSD with KLZE and only use for ice racing with special 13 inch special studded tire (overhaul diameter almost like a regular 14")
The reason i would like to change that ratio is because most of the track we're running on have short straight line but a little to long to stay in 2nd so i have to shift third than back to 2nd almost at the same time...
Any suggestion??? Do you know about possible gear swap,...
![Image](http://i139.photobucket.com/albums/q295/IceRacing_album/Photo20racing20team20certiguard2003.jpg)
![Image](http://i139.photobucket.com/albums/q295/IceRacing_album/QGlace2007_0210_304.jpg)
