front caliper bleeder and clutch master cylinder bleeder
Steeb
Post by Steeb »
can they use the same speedbleeder??
thanks!!
mitmaks
Post by mitmaks »
I think so. how big is clutch one? Ive got 9mm on front calipers and 8mm on rear
Steeb
Post by Steeb »
i got the part numbers here from their website but i dont know which part number is which size.
front
SB8100
rear
SB7100
does anyone know if the clutch master cylinder uses the same bleeder as the front calipers or the rear caliper?
Steeb
Post by Steeb »
:arrow:
Steeb wrote: does anyone know if the clutch master cylinder uses the same bleeder as the front calipers or the rear caliper?
anyone?
mitmaks
Post by mitmaks »
can you measure your stock ones?
Steeb
Post by Steeb »
i dont have stock ones on the calipers. if i take the one off the clutch cylinder, i have nobody to help me bleed it. :(
mitmaks
Post by mitmaks »
Ive got the stock ones if you need them. Anyways rear ones are 7mm (3957) and front ones are 8mm
mitmaks
Post by mitmaks »
3955 7mm rear
3957 8mm front and clutch master cylinder bleeder.
