hello to everyone. i was wondering if i can buy a KL block with pistons and crank in it, then fit into the k8 cylinder head and run it with stock computer+harness and the JE50 VAF?if the a/f ratio is too rich or lean,can i just tune it with a SAFC?i think a k8 tranny coupled with a KL engine should be very fast.
like everyone will tell you use the search fucntion. but i will save
you time
No K8 heads do not bolt onto KL blocks.
Full fx designs body kit, Apex lowering springs tokico struts, walbro fuelpump, klze, 17" sachhi wheels, b'm short throw shifter, ractive frount and rear tower bars, kl36 ecu. all for sale....pending
