Valve adjustment shims?
Posted: December 30th, 2006, 5:08 pm
Where can I order these shims and the 'special tools' needed to install them?
thanks
Nick
thanks
Nick
The Worlds First and Largest Mazda MX-3 Forums
http://mx-3.com/phpbb3/
Even then you can't shim a HLA due to the way Mitsubishi designed them. Unless someone has done a conversion to solid lash adjusters the MX-3 never had solid lash adjusters until '97 and only them on the 120hp B5-ZE.JWMotorsports wrote:The only way you'd need shims on that style lifter is if cut the valve stem to short after doing a valve job on the cyl head. If they cut the valve stem height to the OEM specs then you don't need shims at all. You would then need to replace the lifter as it is damged internally. They use oil pressure to stay pumped up to full height, hence the name "self adjusting".
