opinion on these rods?
Dali
Post by Dali »
http://forums.probetalk.com/showthread.php?t=1701214694
starting to make a list for a ze rebuild, not much info on these but....
Bling Bling
Post by Bling Bling »
Mine are factory ZE rods if you are looking to buy some that are in great shape!!
Stacy Whitrick
MX-West Calgary
http://www.cardomain.com/ride/1335558 UPDATED June 6,07
94 GS, Green Envy Pearl QUESTION: Does my car fit the RICE category?
Spinkx79
Post by Spinkx79 »
I have a set. They are beautiful. Im trying to get some custom pistons for them.
What kind of info are you looking for? They are based on the Mellinia s rod specs, just alot beefier. And i mean alot. :wink:
Mnemonic
Post by Mnemonic »
get kj rods, there stronger and better, though you will have to do some custom work to make fit with piston but it has been done before
01 Lexus Is300 (LS2 Project)
93 Mx3 SE 2.5 KLZE (sold it)
ruthless_mx3
Post by ruthless_mx3 »
those things are sweet lookin and not a bad price either. Makes the stock rods look like toys.
93 MX3 GS SE KLZE -- RIP May 1, 2011
14.007 @ 98.46 1.991 60ft -- the only time she made it to the 1/4 :(
92 MX3 GS aka Goldmember - I'm trying to keep the legend going and as always credit to Andy for starting the legend ;)
sc61 currently @ 8 psi, wiseco 10:1 pistons, K1 rods, ported ze heads w/ kl31 cams
Spinkx79
Post by Spinkx79 »
Mnemonic wrote:get kj rods, there stronger and better,
You base this on what?
papa roached
Post by papa roached »
just ordered me a set, boy i cant wait to do my engine
