Is it Posable to Swap a V4 out for a v6?
Posted: October 6th, 2006, 9:50 pm
I was just wondering if its posable to swap the V4 I have and buy a V6 and have it put in. My car has no balls
The Worlds First and Largest Mazda MX-3 Forums
http://mx-3.com/phpbb3/
Whys isnt it a drop in? Everything bolts up without modification.SuperK wrote:I too wanted the ZE in my car, '95... but alas, twasn't a drop in.
I am in love with the interior of the newer models, so I can't go for the v6 version, either
Next weekend, Im pulling my RS motor and tranny, Pulling my GS motor and tranny an putting it in my RS.
not to mention the Shifter linkage, shifter, all the clutch lines and resivour junk, cluster for the electronic speedo sensor.... etc I am sure you know what ya need.Tunes67 wrote:Next weekend, Im pulling my RS motor and tranny, Pulling my GS motor and tranny an putting it in my RS.
LOL Your gonna be doing a lot more than just swapping motors and trannies LOL
Swapping wiring harnesses... ecu.. suspension... steering rack & gear box converting your RS from a ATX to MTX.. so you will be swapping the pedal assemblies.. serious man.. this is not going to be a simple swap. My advice.. since you have the RS indoors. Strip it. Strip the engine bay of everything.. strip your interior out.. seats center column.. everything.. Once you have the RS a shell.. Start taking parts off the GS... make a list and prioritize everything.. it will go a lot smoother![]()
Your kinda lucky cause you have a complete donor car to work with.. so a strip and swap wont be so bad. You can always do the rear end swap & disc brake conversion after you finish with the front end (though I would swap the struts before driving it too much just to be safe)
Tunes67
Actually his RS is a 95 so he wont need to swap thatcluster for the electronic speedo sensor
shifter linkage is the same, you can keep the steering rack and pump also, same with resivour, you dont' need to swap peddle assemblies if you already have a MTX ... you should change the radiator but don't have to.... it isn't as hard as people think i started witha v6 and put in a I4 (well it isn't in yet but almost)D323 wrote:not to mention the Shifter linkage, shifter, all the clutch lines and resivour junk, cluster for the electronic speedo sensor.... etc I am sure you know what ya need.Tunes67 wrote:Next weekend, Im pulling my RS motor and tranny, Pulling my GS motor and tranny an putting it in my RS.
Tunes67
