KL Engine Internal Upgrading (Please Sticky so I can edit)
Posted: October 2nd, 2006, 12:46 am
This will be an updateable list of the upgradable parts for the KL engines. This list is just started from the importperf website and I would LOVE help from all of you to make this as complete as possible!
Please make this a sticky as it will be updated alot and I don't think I can do that when it's in the faq section? If I can, thats fine, but I do want people to be able to post to it so they can tell of new findings.
KITS AND COMBOS ARE ON THE END!
Bearings
Toga HP
http://importperformanceparts.net/impor ... -ford.html
Main Bearings - $59
Rear Bearings - $55
Main and Rear Set - $109
Clevite
http://www.engineparts.com/
Can't find any info
Topline OEM
http://importperformanceparts.net/impor ... ford1.html
Main Bearings - $35
Rear Bearings - $29
Camshafts
Topline OEM
Camshaft - $199
Gude
http://www.gude.com/Cams/cam_mazda.html
No Price Listed
Clutches
(Prices of Clutches vary depending on what you want, heres the companies that I have found that sell clutches for the G series.
ACT
http://www.importperformanceparts.net/i ... mazda.html
Clutch Masters
SPEC
http://www.importperformanceparts.net/i ... s-all.html
Unorthodox Racing
Connecting Rods
Pauter
http://importperformanceparts.net/impor ... -rods.html
Pauter Rod Set - $999
Topline OEM
Topline OEM Rods - $39 each
Pro Topline Millenia S Rods - $55 each
Crank Pulleys
Unorthodox Racing
http://importperformanceparts.net/imports/ur_us6.html
Ultra Series Crank Pulley - $192
Crankshaft
Topline OEM
http://www.importperformanceparts.net/i ... azda2.html
Topline OEM Crankshaft Kit - $289
Engine Mount Member Bushings
SRD Performance
http://sites.rapidus.net/stpierlu/srd/transmission.htm
2 Front and 2 Rear - $57
Exhaust Gasket
Toga Performance
$59 Each
Flywheels
Fidanza
http://importperformanceparts.net/impor ... _ford.html
Lightweight Flywheel - $359
SPEC
$399
Unorthodox Racing
$459
Head Bolts
Adjusa Head Bolts
$77.99
Head Gaskets
Adjusa MLS Head Gasket
$49 each
Fel-Pro
PermaTorque MLS - $99 each
Headers
Pacesetter
Black Paint - $209 ArmorCoat - $349
Lifters
Topline OEM
30mm - $15 each
33mm - $19 each
Piston Rings
Ross Racing
http://www.importperformanceparts.net/i ... rings.html
$22 each
Pistons
Topline OEM
http://www.importperformanceparts.net/i ... ford1.html
$191 (with rings)
Wiseco
http://www.importperformanceparts.net/i ... _ford.html
$629 (no coating or rings, can be bought to fit Millenia Rods)
Retainers
Ferrea Titanium
http://www.importperformanceparts.net/i ... iners.html
$13.50 Each
Throttle Bodies
Corksport RCE
http://corksport.com/store/category/4v8 ... ngine.html
$255 + $125 core
Thrust Washers
Topline OEM
$15
Valves
Topline OEM
Intake/Exhaust - $9
Ferrea
Intake - $21.99 Exhaust - $22.99
Valve Seals
Toga
$79 set
Valve Springs
Ferrea
$19.50 Each
PERFORMANCE KITS AND COMBOS
HP Performace Kit
http://importperformanceparts.net/imports/pek-ford.html
Complete Gasket Set
Hussey Copper Gasket
Ross/Wiseco Forged Pistons (either 9.1-1 or 10.1-1)
Ross Performance Rings
Performance Wrist Pins
Toga HP Main Bearings
Toga HP Rod Bearings
Thrust Washers
Timing Belt
Expansion Plugs
Standard Kit - $1159
With HP Millenia Rods - $1489
Available with Pauter Rods - N/A
Kit with Toga HV Oil Pump - $1319
With HP Millenia Rods - $1649
Full Gasket Sets
Adjusa
- Head Gasket
- Viton Valve Stem Seals
- Valve Cover Gasket
- Int. & Exh. Gaskets
- ALL other required sealing gaskets, strips & plugs.
- Oil pan gasket (where applicable timing gasket, rear main seal)
$209
Toga HP
MLS Head Gasket (for gas & turbo to 30 psi)
TOGA Performance Valve Seals (Teflon)
TOGA Crank Seals
$369
Connecting Rod and Piston Combo
IPP
Wiseco Pistons with Pro Topline Millenia S Rods - $929
Wiseco Pistons with Pauter Billet Rods - $1589[/b]
Head Packages
Gude
http://www.gude.com/Head/hp.htm#mazda
* Ported and Polished Cylinder Head
* High Compression Radius Cylinder
* Racing Valve Grind
* Ported Intake Manifold
* Ported Throttle Body
* Camshaft(s)
* ECU (ECU's may NOT be available in all head packages. Call for details)
Spacer Kit
Outlaw Engineering
http://www.outlawengineering.com/MazdaK ... Frame.html
Includes intake manifold spacers, throttle body spacer, gaskets, coolant bypass fitting, installation kit, detailed instructions and OUTLAW ENGINEERING decals!
$105
Bearings
Toga HP
Main Bearings - $59
Rear Bearings - $55
Clevite
Can't find any info
Topline OEM
Main Bearings - $35
Rear Bearings - $29
Camshafts
Topline OEM
Camshaft - $199
Gude
No Price Listed
Clutches
ACT
Clutch Masters
SPEC
Unorthodox Racing
Connecting Rods
Pauter
Topline OEM
Crank Pulleys
Unorthodox Racing
Crankshaft
Topline OEM
SRD Performance
Exhaust Gasket
Toga Performance
$59 Each
Flywheels
Fidanza
SPEC
$399
Unorthodox Racing
$459
Head Bolts
Adjusa Head Bolts
$77.99
Head Gaskets
$49 each
Fel-Pro
Headers
Pacesetter
Lifters
Topline OEM
30mm - $15 each
33mm - $19 each
Piston Rings
Ross Racing
$22 each
Pistons
Topline OEM
$191 (with rings)
Wiseco
Retainers
Ferrea Titanium
$13.50 Each
Throttle Bodies
Corksport RCE
$255 + $125 core
Thrust Washers
Topline OEM
$15
Valves
Topline OEM
Intake/Exhaust - $9
Ferrea
Valve Seals
Toga
$79 set
Valve Springs
Ferrea
$19.50 Each
HP Performace Kit
Complete Gasket Set
Thrust Washers
Timing Belt
Expansion Plugs
Full Gasket Sets
Adjusa
- Head Gasket
$209
Toga HP
TOGA Crank Seals
$369
IPP
Head Packages
Gude
* Camshaft(s)
Spacer Kit
Outlaw Engineering
$105
