OK so i'm starting to replace some parts for my ZE
Are all the parts for a KLDE? Or are some KLZE specific? I'm talking about things like..
Pulleys
Gaskets
Plugs/Wires
Oil Filter
PVC Valve
Water Pump
KLZE Parts
- solo_ryder
really? im using the k8 ones and drives fine
-hec
- mx3autozam
umm ya the 4cyl ones are the same as the k8 BKR5E-11...the mx6 ones are ZFRsomethinmg and tehre a bit longer. Some people ahve had issues with teh higher compression and the piston hitting the plug and closing the gap so they recomend the k8 ones but there the wrong heat range. so the ones to go with are BKR6E-11 Tahts what i sue and tahts what corksport sells as wellDeimos wrote:everything else yes, just ask for it from an mx-6 v6
and what's the diff between the 4cyl and v6 plugs?
i'm using NGK V6 MX-6 ones...would there be any benefit of using the 4cyl ones?
John
93 Mazda MX3 KLZE Turbo
- solo_ryder
