should i swap my 1.6 4-cyl for a 1.8 v6
magiccowinuse
Post by magiccowinuse »
I found a 1.8L v6 engine in a mx-3 at a junk yard i dont know if it is worth switching out my 1.6 4-cyl for this 1.8. How hard would it be on a scale from 1-10. What would i need other than mounting brackets? Would I have to get a new trans for this engine?
1994 1.6L White MX-3 - Daily Driver
1995 Red MX-3 -Project
atlantamx3
Post by atlantamx3 »
THat would be a waste of $$.
Swap in a BP instead and get the same HP for less $$ and it will be tons easier too.
~Perry
Please visit
http://www.mx3-atlanta.com
magiccowinuse
its just getting my hands on one..that engine which i could talk down the price was at 500 i'd have to find a BP some where close
lakersfan1
Post by lakersfan1 »
You could get a K8 for free. But the added work including ripping out the wiring harness is not worth it. If you've already got the 4 cyl, find the BP.
1990-1994 Mazda Protege LX
1992-1993 Ford Escort LX-E
1991-1996 Ford Escort GT
1991-1996 Mercury Tracer LTS
1994-1997 Kia Sephia GS
I'm sure you can get one under $500 between the local junkyards. I'm not sure which ones are out as far west as you are, but there's one on North Ave and Cicero just inside the city and another in Summit off I-55 that are pull-it-yourself lots which are usually cheaper.
If you'd rather have the engine just shipped to your door, there are Japanese BP on eBay all day long: http://cgi.ebay.com/ebaymotors/JDM-MAZD ... dZViewItem
magiccowinuse
Nice, thanks. now these engines would still have to be rebuilt correct(ebay)?
lakersfan1
magiccowinuse wrote:Nice, thanks. now these engines would still have to be rebuilt correct(ebay)?
The ones from Japan typically have a maximum of only 50K miles. They should give you another 100K miles of trouble free use. If you got a junkyard one, I'd probably rebuild it as they usually come from cars with over 100K miles.
If you decide to rebuild, full engine kits are about $350 with new oversize pistons. Machine work if you assemble yourself would be about $300 probably.
hgallegos915
Post by hgallegos915 »
I got my ze on ebay and it rules.. i got the kfze there also and it was ok .
Dont swap from 4 cyl to 6... its a hard!! harness and today iw as looking at the axles shafts hubs.. different.. :S only think in common is struts.
-hec
magiccowinuse
lakersfan1
magiccowinuse wrote:http://cgi.ebay.com/ebaymotors/JDM-MAZD ... dZViewItem
is that a good one?
No. That's an FS engine. Completely different. You want BP. I don't know why that retard listed an MX3 as direct swap.
magiccowinuse
good, im glad im checking with you guys thanks for the help....this one will work though correct?
lakersfan1
Yep. That one will work. Then follow BP install journal:
http://www.mx-3.com/phpbb2/viewtopic.php?t=34815
sampsonmx3sv
Post by sampsonmx3sv »
The K8 wont give you much hp increase. Follows what those guys said and to a ZE or Turbo set-up.
5speedMX
Post by 5speedMX »
How much hp increase will the bp give over the stock 1.6L engine?
It ain't done 'til it's done right.
If you have a 92-93, it has the SOHC engine, 88hp
If you have a 94+, it has the DOHC engine, 105hp
As for BP's
Stock BP is 130hp
Stock BP GTX turbo is 180hp
Stock BP GTR Turbo is 210hp
CalgaryMx-3Guy
Post by CalgaryMx-3Guy »
I want gtr turbo
