ENGINE DETONATION
ENGINE DETONATION
today my 93 mx-3 rs died....I was driving down the road and it was ticking(bad). and there was a loud clunk rpms dropped and it has not run since.... i have no idea what happened but it won't even turn over. the starter trys and it won't turn over. So i'm thinking I threw a rod. So now i'm going to pick up a bp tomorrow and start my swap hah....The engine made it 235k miles so i'm pretty dang happy with that. I bought it 4 months ago with 220k. so thats it for the sohc motor
yeah
well i know it didn't have low oil. I"m pretty sure i broke it because the night before i did some racing...I drove it really really hard and I noticed it when i got home that that night. and well I think i killed it then....it's cool though bc i've wanted a good exuse to do this swap so now it's definently going to happen tomorrow....as long as i don't mess it up. I still gotta find a good bp ecu and harness
im just saying a ticking noise on these engines is infamos for low oil pressure. i thought i had full oil on mine and almost destroyed my engine cause my mainseal broke and lost all my oil but it went into the bell houseing so i didnt know about it. crack your tranny bolts a bit and see if oil comes out. if so. your pistons are prolly a permanant part of your block now
ha
yeah Its possible, I'l let you know what i find today when i start pulling my engine.
also i have a quick question can i take all my accesories of my sohc and put them on my bp? bc the motor im' buying only comes with the motor...
- Limegreen mx-3
Re: ha
dude on is a B6-ME design differently forn the BP-DE. the header and intake manifold from the sohc will not bolt up to the BP. the PS and A/C will bolt up read the damn 4cly faq am sure more that 100 people have done the BP swap i have done it more than 10 timeson my mx-3 and other customer cars that wanted the BP swap in there MX-3Gottagofaster wrote:yeah Its possible, I'l let you know what i find today when i start pulling my engine.
there is a sticky on a BP swap guide 1st post on the 4cl. technical/performance
since you're doing a swap, I would say anything questionable or stock from the original should go. the alternator can be fun though take it to a motor rebuilder and have it rebuilt and rewound, meanwhile take the housing and have it powdercoated. if you're going for pure performance I would only keep the things that work acceptionally well because one bad part can always cause a chain reaction of other parts straining. I'd replace the plug wires and disty especially, the engine going could have fried both.
- ryanlindenberg
throwing an engine rod and/or running the engine without oil will not cause the disty or wires to be "fried". if your disty worked fine, you might as well keep using it. replace your wires if they need it, if not they should swap right over to the BP.
CARDOMAIN WITH UPDATED PICS
