Car dies when hot
Car dies when hot
Okay. I'm having this problem for about 1 year now. I just did complete tune up yesterday and thought the problem will be fixed, but not. My car stumbles and sputters when engine is hot. It gets worse if A/C is on. For example, I drop by grocery store, get out, start the car, turn on A/C and put my gear on reverse and car sputters and dies. In the morning right after I start the car, this problem is hardly there. It stumbles little bit when in reverse. Sometimes car dies at stop light. I also have this power loss when I hit the accelator from dead stop. There's a couple of seconds hesitation.
I checked vacuum leak, compression, replaced thermostat & coolant temp sensor, add injector cleaner, cleaned throttle body...etc. You name it. I did everything I could. What is it? Any idea? BTW, it's 95 MX-3 4 cyl A/T.
- Tunes67
Use the online shop manual and do the diagnosis checks for your distributor and coil. Heat causes coils to break down.. they stop working efficiently.. the results would be no or little spark to your spark plugs. At least that is what I would check first. Hope this helps. Cheers
Tunes67
Tunes67
"So long.. and thanks for all the fish!" "Momma says VW Bugs are the devil" "This one time at band camp.. I stuck a flute in my Throttle Body" ![Wink ;)](./images/smilies/icon_wink.gif)
O2 sensor & HEI mod
94 Mx-3 Precidia
- ryanlindenberg
could be your coolant temp sensor for your ecu also.
CARDOMAIN WITH UPDATED PICS
had that same problem thought it was the whole disty turned out it was just the cap.
I bet if you open the hood and have the engine running you can put the metal end of the screw driver down beside the disty cap you will see an electrical arc. this is because your cap is bad and your getting mosture into the cap stopping the disty from working properly...
Spray some silicon spray over the cap I would bet your problem will temerarly go away. give it a shot it wont hurt. this way you know its not the whole thing..
thx ven
thx ven
STeve
1996 Black MX-3 GS
North Bay, ON Canada
If your in North Bay lets hang out and go for beers
1996 Black MX-3 GS
- xtreme velocity
i have the same problem..only mine wont quit die on me..just feels like it would die..i made a post bout it..under rough idel..thanx for the help..if i get any progress i will post..
Current:
93 F-250 Diesel Coal Roller (For Sale)
06 RX-8 1.3 Rotary AT 6 speed (All looks)
79 Ford Courier 2.3 4cyl 5 speed (lil Pete)
Past:
05 Mazda RX-8 1.3 Rotary MT 6 speed
90 Mazda Miata 1.6L 5 speed 45k miles
94 MX-3 RS DOHC 5 speed 90k miles
Past:
Finally fixed!!!!
Okay. I finally fixed this problem. My car runs and idles perfect now. This is what I have done in order. My tune up was up, so I was able to drop some money with no problem.
1. Spark plugs
2. Spark plug wire
3. Distributor Rotor & Cap
4. Timing belt
5. Water pump
6. Accessory belts
7. Thermostat
8. Coolant temperature sensor
9. Intake tube(There was a huge crack)
10. PCV Valve
11. Some old vacuum hoses
12. Sea Foamed throttle body, crank case and put some in gas tank
None of the above fixed the problem. We are having over 100 degrees in Texas in these days, and my car died all the time at the stop light especially in the afternoon. I had to turn off the A/C and put in neutral to keep the car running. I didn't want to replace whole distributor unit because it was expensive, but I had no choice. Paid $345 including tax at local dealership. That was with 10% discount. It was rebuild one, so I had to return the core. Anyway, replaced it and guess what? My car runs perfect now. I had knocking noise and it's gone too. Thank god this problem is finally fixed. I guess it'll be good for another 10 years from now on. I hope this helps.
1. Spark plugs
2. Spark plug wire
4. Timing belt
5. Water pump
6. Accessory belts
7. Thermostat
10. PCV Valve
- Limegreen mx-3
95_mx-3 what part of texas u in.
- Tunes67
No worries man
Thats what is so very cool about this website.. its more than a website.. its a community. And everyone helps when they can. Cheers ![Smile :)](./images/smilies/icon_smile.gif)
Tunes67
![2 Thumbs Up :2thumbsup:](./images/smilies/2thumbsup.gif)
Tunes67
- xtreme velocity
Re: Finally fixed!!!!
zamn..i dont have that kind of money..lol..i will do it slowly n see wut happens..95_mx-3 wrote:Okay. I finally fixed this problem. My car runs and idles perfect now. This is what I have done in order. My tune up was up, so I was able to drop some money with no problem.
1. Spark plugs
2. Spark plug wire
4. Timing belt
5. Water pump
6. Accessory belts
7. Thermostat
10. PCV Valve
Current:
Past:
Past:
"zamn..i dont have that kind of money..lol..i will do it slowly n see wut happens.."
I hear you, but I haven't spent any money on my MX-3 except regular tune up, oil and filters for a long time. It's been very reliable. I didn't do everything at once. I did small things(plugs, wire, rotor, cap, hoses and intake tube...etc) myself at home first little by little, and then I went from there. If distributor didn't fix it, I was going to move on to O2 sensor, fuel pressure regulator, fuel pump & injectors and such. I've been having this problem about an year and recently I wasn't able to drive and felt unsafe. It'll be okay for you guys for a while, but eventually it'll become a big problem. At least that's what happened to me.
