![Image](http://memimage.cardomain.net/member_images/6/web/2214000-2214999/2214141_84_full.jpg)
is this it? if it is i need to know 2 things.
i need someone to conferm its a pwm style iac valve.
i also need someone to conferm that the 1 wire going to it would be signal and it uses the mounting bolts as ground.
Bochek
i only have 1 wire comming outta it, from what i can see.ryanlindenberg wrote:yep that's your IAC or BAC valve (i've heard them called both). mine is wired up to a PWM output on my haltech....so i guess it would be "PWM style".
on my haltech, one wire goes to the PWM output, the other is wired to 14.7 volts +.
they sound great. they are not free air, but im uing them as free air, 25 watts per sub. 4 ohms. high quality everything, except for the subs themselves.ryanlindenberg wrote:are those free-airs?
mine don't pound very hard but i don't usually listen to my music that loud anyways. how do yours sound?
has anyone heard of bazooka tubes??ryanlindenberg wrote:are those free-airs?
