weird reverse?
weird reverse?
sometime i push in the clutch to get in reverse and it doesnt go in so i have to let off and push in the clutch again, anyone have this problem? im NOT rolling while this happens.
- ryanlindenberg
it happens to alot of people.
CARDOMAIN WITH UPDATED PICS
- MechaManZero
well it could be one or the other can't tell you. How often does it do this and explain the situation in detail. It appens a lot for some reason when you first start the car usually.
Çlark
![Image](http://i64.photobucket.com/albums/h192/Mechamanzero/MX-3/2mx3.jpg)
95 Mazda MX3 4 Banger
Currently: H&R Lowering springs, BPT from a GTR, 18.5x6x3.5 same side inlet and outlet intercooler, Centerforce Dual Friction clutch
For BPT Frorums - http://www.aokforums.com/mazdaengines/
I have the same problem on occasion, I think it is normal.
I can tell you what I do and it works for me.
I release the emergency brake and let it roll back just a little.
Then hold the brake down to stop it.
Then it will normaly go into reverse.
If I'm not on an incline I just have to really slam it into reverse sometimes. Most manuals are like that. You have to use the bowlers grip.
Hope this helps.
Hope this helps.
