I think i have an oil leak, but i am not sure.
So near my engine, by the spark plugs, there is something that seems to be a symptom of an oil leak, but i am not sure.
here are pictures of what i am talking about:
http://img.photobucket.com/albums/v194/ ... C06259.jpg
http://img.photobucket.com/albums/v194/ ... C06258.jpg
http://img.photobucket.com/albums/v194/ ... C06257.jpg
As you can see, there seems to be some grime located under the spark plugs. Is this a sign of an oil leak? I was told it was, but a minor one. I have driven the car many times, and it seems to be doing well.
And if this is an oil leak, what must i do?
Thank you for the help. If you have AOL instant messenger, please feel free to I.M. me. Any information would be greatly appreciated.
- ryanlindenberg
yea looks like the valve cover gasket...it will probably take you like 30-45 minutes to change it if you do it yourself (which i highly suggest, a mechanic will rip you off). since you have the SOHC engine it will probably even take you less time than that.
CARDOMAIN WITH UPDATED PICS
- ryanlindenberg
yea i had to use rtv sealant with the gasket...you don't need too much sealant though. my gasket fit perfect.
- MechaManZero
Don't be cheap get a rubber felpro valve cover gasket lol. It is pretty easy to see since oil is dripping right under the cover.
Çlark
![Image](http://i64.photobucket.com/albums/h192/Mechamanzero/MX-3/2mx3.jpg)
95 Mazda MX3 4 Banger
Currently: H&R Lowering springs, BPT from a GTR, 18.5x6x3.5 same side inlet and outlet intercooler, Centerforce Dual Friction clutch
For BPT Frorums - http://www.aokforums.com/mazdaengines/
