The weird sounds xdrilled and slotted make....can we fix it?
Ok, I was fine with a bit if chatter, I knew it was going to happen everything what not...heres what I don't understand...
are the xdrilled and slotted rotors directional....
while driving forward there is a very annoying and loud screeching sound, like metal is rubbing on metal, I thought it might be the tire rubbing the strut...nope it has clearance....
My two options are this...tell me what you think
The rotors are directional and the slots and holes are going in the wrong direction...they are opposite, the sound is coming from the front....the rear there is no sound and the slots are facing the other direction....
Heres a key factor as well...no sound is heard when the car is in reverse...not even from the rear but the rear pads arnt bled correctly, the ebrake doesn't hold....I think the front are perfect, but I believe it has to be the fact that maybe just maybe the rotors are directional?
Oh and Tokico HP and Intrax....damn the car sits low....I bounce off the strut on bouncy turns....
http://www.cardomain.com/ride/2385931/4
Car Name - Elsie (LC)
Car Type - 92 Black RS Stock 190k
Car Name - (yet to be decided)
Car Type - 93 (soon Black) GS KLZE 130k
- PATDIESEL
The slots on most are directional. The vanes go " \ " this way when looking at the rotor on the car.
This is the front wheel
![Image](http://memimage.cardomain.net/member_images/9/web/2385000-2385999/2385931_19_full.jpg)
this is the rear wheel
![Image](http://memimage.cardomain.net/member_images/9/web/2385000-2385999/2385931_20_full.jpg)
Both on the passenger side
Additionally, all of Brembo's slotted discs are directional as well, regardless of the vane geometry. The discs should be installed such that the end of the slot nearest the outer edge of the disc contacts the pad first. Please see figure.
- PATDIESEL
Your front one looks right, but I cannot be sure without more pic to see which wheel we are looking at. Anyway, try and reverse the front to see. It is not much more than an hours work...
stupid solition.....dust shield was touching the rotor
- ryanlindenberg
According to that, your front rotors are switched around...your back ones are fine.Additionally, all of Brembo's slotted discs are directional as well, regardless of the vane geometry. The discs should be installed such that the end of the slot nearest the outer edge of the disc contacts the pad first. Please see figure
CARDOMAIN WITH UPDATED PICS
- sk8erdude802
Yeah that sound is aweful. I bent mine replacing a ball joint and about droped a load in my pants when I started driving down the road. lol
Steve-O
Steve-O
93' MX-3 GS SE ZE - Sold to Acheron1502! SOLD!!!
93' MX-3 GS SE - R.I.P. K8 with Integra CAI, HEI mod, Koni inserts with H&R's,drift kit, Kicker KX400.1 and KX200.2 amps, 2 kicker 12s, set of 6x9's. Custom trunk enclosure
MyFeedBackThread
![Image](http://api.photoshop.com/home_edc8ea33dca94cb28ff3b581e3c4bdf8/adobe-px-thumbnails/9f2c69c269364749851a91708b58acd2/256.jpg)
^^^^^ Click on image for my work log ^^^^^
MyFeedBackThread
