radiator performace
radiator performace
Hey does anyone know where i could locate a performance radiator for my 1995 mx3 with 1.8bpt swap
1995 J-Spec Az3, BPT swap, mazda speed eibach springs, mazda speed swaybars, mazda speed exhaust, mazda speed shock tower bar, mazda speed bodykit, sr shocks, disk-brakes all around,turbox boost controler, honda del sol act pressure plate, fmic 20x12x3
Re: radiator performace
Rad performance comes from size, airflow and the metal they're made of..nickmx3 wrote:Hey does anyone know where i could locate a performance radiator for my 1995 mx3 with 1.8bpt swap
Low-Pro High CFM fans (dualies) and a thicker rad will give you lower temps your looking for in a turbo application...
i dont know why you would need one, ive never heard of anyone having overheating problems with a bpt.
what temp is your engine running?
Bochek
Bochek
I dont have an overheating problem my radiator has a small crack i need to replace it
ahh ic if it where me, id just replace it with a stock one, but w/e
Bochek
Bochek
- MechaManZero
Blooprint put a honda rad in his car. I think atlantamx3 knows him. That seems like a nice upgrade.
Çlark
![Image](http://i64.photobucket.com/albums/h192/Mechamanzero/MX-3/2mx3.jpg)
95 Mazda MX3 4 Banger
Currently: H&R Lowering springs, BPT from a GTR, 18.5x6x3.5 same side inlet and outlet intercooler, Centerforce Dual Friction clutch
For BPT Frorums - http://www.aokforums.com/mazdaengines/
Most of the time the AT radiator is larger than the MT one for our cars... if you have a MT one swap it out for the stock AT one and it will cool better.
That or go custom if you have the cash. Dual or triple core would cool like a mofo... keep in mind though that you do have an ideal operating temp... getting cooler than its designed for can actually hurt performance and lower MPG's.
GS + BP + T3 + 9lb flywheel - some dead weight = ![Wink ;)](./images/smilies/icon_wink.gif)
- ryanlindenberg
that's what the thermostat is forD323 wrote: keep in mind though that you do have an ideal operating temp... getting cooler than its designed for can actually hurt performance and lower MPG's.
CARDOMAIN WITH UPDATED PICS
