Major engine problems!
Posted: June 21st, 2006, 9:24 am
Ok i have a handfull of questions
1. My car sometimes dies on me like it did when i had a bad ignition coil so i did the HEI mod and it was working great for about 4 months and now its not doin it often only on long drives but then when it does cut out i found out if i pour some water in between the valve cover and the fresh air duct it hits the exhaust manifold pipe and cools off and then the car starts right back up thats the only time it will start bak up is when i cool it off! otherwise it will jus crank but wont start.
2.I think its part of the problem but my check engine light comes on after my first problem started happening and the car will still drive and everything will be ok but as soon as the engine gets to warm/hot it will do it again.
3. When i installed the HEI mod was i also supposed to replace the disty with it or was it not necessary.?
a little background here wat ive done
HEI mod
new alternator
new wires ngk
new plugs ngk
new cold air
new fuel pump
new fuel filter
new radiator
new water pump
all belts new
new p/s pump
so my 92 gs is doin pretty good now except for those small problems any ideas will be appreciated!
HEI mod
new alternator
new wires ngk
new plugs ngk
new cold air
new fuel pump
new fuel filter
new radiator
new water pump
all belts new
new p/s pump
