Cheap Alternative For Poly-Stabilizer Bushings
Well I was in desperate need of a new Stabilizer bar bushing as mine was falling into pieces. So i decided to take mine to AutoZone, and source a replacement. They told me that it was a dealer only item, so i was s--- outta luck.
Well i was determined to find something that would work, so after walking around i ended up in the section with Endlinks. I found a universal kit, which included 8 Endlink bushings, 8 Washers for bushings.
I will try and get some pics ASAP, but i will explain what i did pretty much. On the stud sticking out of the tranny i placed one washer, then got 2 of the endlink bushings put them back to back and squeezed them into the stabalizer bar....perfect fit! Then i slid the stabalizer bar over the stud...the back washer acts as a back stop for the bar and bushings....then i got another washer...placed that on over the stud....and then installed the 14mm bolt back on and tightened it.
The result is a nice stiff Stabalizer bushing set that cost cheaper than SRD Stabalizer bushings, granted i only used a set of bushings so i still have another 3 sets and 3 sets of washer that i can sell or do as i wish.
So if anyone is interested hit me up and i can sell the rest of what i have and take pics and its a direct drop in and takes no more than 15 minutes to install.
I'm working on pics....What u guys think so far?
- JWMX3
Re: Cheap Alternative For Poly-Stabilizer Bushings
Pretty sure he means the shifter base linkage.. vibration dampening bar or whatever the hell its called....... Not a sway barSlammed6 wrote: On the stud sticking out of the tranny i placed one washer, then got 2 of the endlink bushings put them back to back and squeezed them into the stabalizer bar....perfect fit! Then i slid the stabalizer bar over the stud...the back washer acts as a back stop for the bar and bushings....then i got another washer...placed that on over the stud....and then installed the 14mm bolt back on and tightened it.
![Confused2 :confused2:](./images/smilies/confused2.gif)
![Image](http://img40.imageshack.us/img40/7481/avatarmx.png)
I'm working on the pics...i will try to get some later tonight...i'll just demonstrate on a tranny outta the car, and if i get my car back on a lift i will take some pics.Sounds nice, but I`d like some pics, have a bit hard time imagining how this works
-nope
The Stabalizer bar is the bar that is also attached to the tranny and then to your shifter. It keeps the shifter in the same distance from the tranny as you alow you to go into gear easily. But under hard acceleration the stock bushing move a lil too much and will cause those shitty mis-shifts.What's a stabilizer bar? You mean an anti-sway bar?
No, definately not a Sway Bar...lol.
No i am not talking about the back of the car, lol.yea lakers some ppl call the stabilizers bars some call it sway bars 2 different names but sill the same object.. and yes pix plz!
No. The bushings at the end/ bottom of the shifter are much smaller. Replacing that will help somewhat in the "play". You can pick them up at Mazda for around 4-5 dollars Canadian. It's the bushing that Slammed has for the end of the "extension bar/ rod"(#29) that helps alot more in the "side to side" play.
Slammed might be on to something because it's so cheap. You can do a 4 person group buy for under $25 USD! lol Now all you need to do, Slammed, is find a replacement for the other bushings. You should take pics of those endlinks.
- mx3autozam
