Painting Wiper Cowl
tallymx3
Painting Wiper Cowl
Post by tallymx3 »
I want to paint my wiper cowl and want to know if anyone can give me any pointers. Thanks for the help in advance. :D
1992 WHITE 1.6l SOHC saving for a BPT swap next year, New interior next month, and new Paint Hooray
mitmaks
Post by mitmaks »
i would use plastic adhesion promoter. Will make paint stick much better. Prep work is the key
Bolverk
Post by Bolverk »
I masked everything around it, hood/windshield. Cleaned it real good then used a primer and two coats of a semi-gloss black spray paint. Looks great.
Hoodzy
Post by Hoodzy »
Bolverk wrote:I masked everything around it, hood/windshield. Cleaned it real good then used a primer and two coats of a semi-gloss black spray paint. Looks great.
is it not easy to take off
its not worth gettin overspray on ur car!!
1995 Creek Mica Blue GS
mitmaks
Post by mitmaks »
I wouldnt be lazy to remove it to paint it
Jacbs2007
Post by Jacbs2007 »
mitmaks wrote:I wouldnt be lazy to remove it to paint it
I don't understand if you're saying he SHOULD remove it, or shouldn't?
1993 GS
-MS front -functional molded hood scoop
-MS molded sides-shaved antenna
-Civic projectors -New black paintjob
mitmaks
Post by mitmaks »
He should remove it, would be easier that way
Neil
Post by Neil »
Its not difficult to remove at all, the toughest screws to get at are the ones on each end that are almost underneath the hood brackets. But they are easy if you've got a short screw driver. Not hard at all
Ever notice anyone driving slower than you is an idiot and anyone driving faster than you is a maniac?
01-03 Civic Projector Swap Tutorial
Bolverk
Post by Bolverk »
I was too lazy to take it off. I had 36 inch masking paper so it was real easy to cover anything that might get overspray. It worked out well.
jrors
Post by jrors »
I'm interested in seeing a pic of your work. Please, post a pic for us if you don't mind.
If you fall, then get back up........Luck favors the prepared
Bolverk
Post by Bolverk »
If you are talking to me, there are a couple pics in my worklog, but they arent close ups. I will grab a couple tomorrow maybe.
tallymx3
Post by tallymx3 »
So back to how i get this done. Once i remove it what should i do for prep and is there a brand of paint that is better than others. Thank you guys for the Help :D
mitmaks
Post by mitmaks »
there paint specially formulated for plastic/vinyl. Abride plastic real well with gray Scotch Brite pad, wipe it real good with wax and grease remover or at least rubbing alcohol. Put some primer on it, it would adhere paint much better in long run. Then once dry you can wet sand primer (get sandable primer) sand it with like 500-600 grit wet-or-dry sandpaper. after its nice and smooth clean it good again and you can go ahead and paint it.
tallymx3
Post by tallymx3 »
Thanks mitmax :D
Hoodzy
Post by Hoodzy »
yah i think i'm gonna do mine too, its gettin pretty mad faded.. just sucks if the paint starts to peel and such
Return to “Appearance”
