Drum to Disc Conversion
Posted: April 15th, 2006, 5:42 am
I must say...
I didn't do the rear disc brake conversion because people were all talking about how you had to replace everything out back and whatever....
I instead replaced all the parts that wear on my Drum setup..which i'm totally happy with...
But a friend of mine just baught a GS and i made him new lines from the front distrobushion block to the rear discs... and while i was under the car i noticed a few things...
-) the forward and trailing control arms are identical to those of the RS
-) the shocks while having an ABS sensor etc. are exactly the same (which wouldn't matter as the RS doesn't have ABS)
-) the performance rod and bushing are all the same and in the same place...
-) the spindle looks hell of a lot like the RS one.. for bolts matching up at least
SOOOOOOo..... todo the conversion your talking remove the drum spindle(which may or may not be EXACTLY the same) mount the hardware... replace the flex lines and go...
Even if i didn't have a shop full of air tools, jacks and stands...
All you'd need is..
- A strong arm and a 3/4 inch drive 1-1/4" Socket(spindle nut)
-21,19,18,17,15,14,12,10,8mm sockets and a 4 inch extension.. And preferably 2 ratchet wrenchs.. because you'll need Two 15,17,19mm's(lower shock bolts...)
-8mm wrench for bleed screws..
-And the page with the tourque specs on the lower control arms, shock tower, and brake nutz and bolts...
I don't know if the piston Gross area is different.. but i doubt it is enough to need a new master cylinder and or Brake booster assembly...
If you didn't have a clue.. it'd take you 2 or 3 afternoon's maybe...I've taken apart my suspension like 5 times now while putting it together..so anyone who's done something like that before could do it in a day...
<END RANT>
All you'd need is..
<END RANT>
