How long is your oil returnline(turbo in spot right ofdisty)
- XxantwawnxX
People who have there turbo in the usual spot for v6 mx3's (right of the disty near the frame.) How long is your oil return line, if anyone knows right of the top of there heads,id appreciate it.
- babyblueMX3
- XxantwawnxX
Thank ya much, my turbo's pretty much in the same place as yours so that helps me out alot..knowing a measurement. All i need is to do the oillines and tap the pan ...: ) and i can get going with the boost.
